I bet it drive better with one. My 2 cents. Pop walked in shop today and first words he said was wheres yer trac bar?that's cause you don't need one w/ a cross spring
The rear Panhard bar on the coil-over CCR chassis is bent (twice) and offset to allow it to follow the housing shape, be as long as possible and still clear the frame rail.
I smell what yer cookin.If you want a McDonald's hamburger, you have to go to Mickey D's
Im no chassis builder but from what i have been reading it needs to be pretty close to level. You had sny luck on yours? You have same setup i have.The money tree is out of bloom at my house too. So, the rear panhard bar shouldn't be at an angle??
Correct. My jeep xj has a 4 link front suspension and my track bar is level on both ends but the center section is on long angle. I will most likely buy CCR's panhard bar.From what I remember, the physical bar need not be as close to level as possible...an imaginary line between the ends does need to be as level as possible. The shape of the bar between the end points is irrelevant.
