Again, lines & proportion. The top of the bed should run parallel to the top of the body. I would fit the bed to a flat piece of ply wood, mount it to a comfortable height, sturdy table, and then trim, reinforce, and finalize before attempting to mount to body. And yes I would look into using plywood to form the "flooring" of the bed. Don't rule out simply running a nice spun aluminum or steel "vintage" type gas tank (rectangle or oval).
John
I gotta glass the bed to body. I think a wood floor will build strength. I channelled body do i figured the bottom of truck bed should be even with bottom of frame rails? Hide frame.What I meant was that the top of the bed should be parallel to the top of the body. Installed height is up to the builder. The present apparent install has the lower lip of the bed attached to the bottom of the frame extension. With the present photos and the angle that they were taken it appears that the bed is mounted too low. No ?
If the line from the dash running back to where the rise in the back starts is angled in relation to the line on the bottom of the body then let your eye and what you like be the determining factor.
Again, photos taken from 3 feet away are basically useless for determining sight lines for frame, body, headers, manifold angle, etc., etc., etc.. Have to get the car outside, on a level piece of concrete, stand back 50 feet and look at it. Take a few pictures. Drink a beer. Take your time.
That sure is a flimsy looking bed.
John
So i should set bed on top of frame rail?I don't recommend you channel the bed. You will need that extra space in there for a gas tank, and battery.
Cooter, if you can "c" clamp the bed below the frame rail, cant you "c" clamp the bed above the frame rail ? Just to see what it looks like ?So i should set bed on top of frame rail?
Takin pics outside now. I be right back with some pics. Looks like crap "C" clamped on top.Cooter, if you can "c" clamp the bed below the frame rail, cant you "c" clamp the bed above the frame rail ? Just to see what it looks like ?
Question to Jim - what is the body line that runs from the dash back to the beginning of the rise in the body called ? It runs vertically across the top of the door to the back.
Doesn't Ron have a combo gas tank/battery box set up for that bed ?
Push it out into the light and check it out.
John
John
