I have 3/4 plywood im gonna put on inside of firewall. Thinkin bout aluminum on engine side.
So your sayin lay the 1 oz mat down in void and then fiberglass resin over that to fill void instead of the fiberglass bondo down in void. Been watching hot rod 101 video. Bob hamilton was showeing the process but my tub is reversed from his.Bondo/fiberglass plywood to inside fire wall as it stands on the fire wall--engine side on a flat surface. then put weights/cement blocks on the plywood and it will be flat when it cures.
On the gap in the floor sides, put strips of mat/cloth in the gap and then fill with resin. As strong as you can get IMHO Same for fire wall...
10-4....this fiberglass aint my thing... First time with this mat,resin. I patched a rusty spot in a car with bondo with fibers and screen door wire once but nothing like this. Thanks yall. Im learnin..Cooter Bondo is a brand, I used filler with the strand in it to install the wood on the sides of the body. As T- Test said cut the fiber glass mat in strips stack them up together to fill the void between the body and plywood then add the resin.
Home Depot or Car Quest.Where is good place to get my supplies?
This looks scary. So the duct tape keep me from getting it where it dont belong.fill void up level with floor and up body to duct tape line. Then use the glass mat over top of that up to tape line. I think i got it?
All you're trying to do w/ the filler is make a smooth transition , or fillet , from the floor to the body . It makes it much easier to lay the mat on a rounded surface than a sharp bend . If you don't have a resin roller , get one , makes it a bunch easier to wet out mat & get rid of air bubbles. Don't use more resin than it takes to wet-out the mat , too much resin actually is weaker..
Watch your mixing ratios very carefully , X number of drops of hardener to X oz. of resin, too much hardener makes weak resin w/ little open time , too little it won't kick..
A 6 oz. batch of resin is alot !!especially if you're learning how to use it..
