yup, i been into the motorcycle books, go cart books... we getting warm.... if i build a bolt with a welded spacer in middle and nut on both ends i could tighten shoc on one side and shackle on other. keep it thin in the middle kinda like speedway shackle?Bike shocks?
Overview of V-Factor Narrow Body Adjustable Length Shock Absorbers - 29020
- 2 in. o.d. of this shock absorber makes it the perfect choice for those space limited custom applications
- Lowers motorcycle up to 1 3/4 in.
- Includes aluminum spacers for proper heim end spacing
- Sold in pairs
- View attachment 11741
im with ya!!!I was thinking the same thing. Keep the shackle side loose and the shock side tight.
Maybe back to back shoulder bolts?
i need a machinest to build me a bolt double ended washer bolt.I was thinking the same thing. Keep the shackle side loose and the shock side tight.
Seasoned motor.. Came out of a running 56 chevy truck. Runs like a champ.. I need to buy some more paint.. Pics soon.As always, how bout an outside, back up a ways, profile shot.
John
BTW, where's the white VHT for the extensions ? Will your motor need to be broken in? Doesn't some one here have a sacrificial set of headers for the break in so you can change over to the nicely painted headers for the car show?
I thought about that. Press brake woukd be nice or get ron to mske me some.cooter, couldn't you put a Z bend in these brackets to offset them a 1/2" more?
