Island Girl
Who knows, maybe old bubble gum would be good enough . . . .
Sorry I brought it up
Bit thin skinned ,are we ?Who knows, maybe old bubble gum would be good enough . . . .
My t was built in the ‘70’s and I had a hard time removing the wood and bondo from inside... grinder required. One thing that I did was drill numerous holes in the oak, ruffened the glass, and mixed resin with the putty when I attached it to give some teeth for mechanical adhesion... it’s all wrapped in glass also. I’m not trying to negate anyone else’s thoughts, just sharing my experience.Almost 40 years ago I lined the inside of my bucket with wood to attach the interior material. I bonded it with Bondo or some type of body filler. Its still hanging in there. Just sayin'.
Bill
I used wide pieces of oak so the door and jambs were one piece, carved to fit, drilled holes in it for the bondo/resin slurry to bite into. Ruffed up the glass on the body, then I cut the door out of the whole thing, that left the jambs in place and they match. Beware, you may get some deviation in the skin, mine pulled in when it cured even though I pre fit the oak. Not a big deal, I just filled and used a body file to straighten it out. I found that adding a little resin to the bondo makes it creamier and easier to get it into crevices, etc. just sharing, not refuting anyone’s ideas. Use very light clamping force, just enough to hold in place, you don’t want to put tension on it. Have fun! Watching you makes me want to uncover mine and get back into it... I left off right after making and hanging the doors. Btw, I found that I have better results with professional grade body filler like 3 m, etc... it’s fresher, creamier, etc than the stuff from local stores. Just my experience. I order just about everything on line. There are a couple auto paint stores, but they are higher priced.I had to do some belt sanding on it to fit.
That looks like some good stuff!!!I used this to bond wood to my body. I didn't have to scuff the fiberglass for it to stick. It was set in about an hour. A few hours later, it was permanent.
3M™ Marine Adhesive Sealant 5200 Fast Cure | 3M United States
