With the reminder you don't want to rattle the rings out of it, trying sticking in another 1° of timing. Keep in mind that detonation can occur without you hearing the death rattle, so keep your eye on all the clues that would indicate you've gone too far. Adding more timing because you cannot hear detonation is walking the high wire without a net.
It's all about remembering a carb has different circuits, to accomplish different things, at different times. Idle mixture determined emulsion introduced at idle. Open the throttle blades and you transition from the idle circuit, to the accelerator pump circuit, to the main jet circuit. That's always the tricky one, because of the multiple transitions. But when you narrow down when a problem is happening and then think about what the carb is doing at that time, it gets easy to start applying your efforts where they will produce the most results.
Yes, there can be some gray areas, where you can fool a carb into doing something it wasn't really intended to do (Screaming Metal, did you ever lighten Holley accelerator pump weights?), but for typical street use, sorting carb issues is not rocket science. People usually create pitfalls by trying to over-think things.
Another thing to remember is when you are trying to zoom in on a problem area, don't make wholesale changes. If a car stumbles on acceleration, don't change fuel pressure, squirter diameters, pump cams and main jets, ignition timing and valve lash, all at one fell swoop, That is the simplest and fastest way to getting yourself down at the dark end of Lost Street. Change one thing at a time and then test the change. Did it help, or did it hurt? If it helped, try giving it a little more. If it hurt, put things back and test to be sure you are back to your baseline. Then go the other direction and see what happens.
All you are trying to do is to make the motor happy. But you have to listen to what it is trying to tell you, so you know what it really wants.
