Yeah, to do it right you have to pull it out and somewhat apart to get the motor clean enough to hold the new paint. We are doing the same thing with my Kid's 455 Olds engine. We built it 4 years ago but the car has never been started, now he wants it a different color as he changed directions on the car. So we pulled it apart completely and are going to use stripper, wire wheels, and sandpaper to strip it back to bare metal, and then prime and paint it again.
Don't worry about the color black, that is what we probably are going to go with. I work in the marine industry, and Mercruiser has painted their engines gloss black forever, with no adverse effects that contribute to overheating.
Something a lot of people don't know is that you can paint an engine with the same paint you use to paint your body. The "secret" is to use epoxy primer first. Doing it this way produces a much nicer looking motor than bug bombing it, and it holds up much better for much longer.
So, spend a little more time and work by pulling your motor out and doing it right. The end results will be so much better. Here is his Olds engine when it was all painted and done.........
And here is how it sits today...........waiting to have the paint stripped back off. :sad::sad: A lot of work down the drain, but it's what you gotta do sometimes. :wall:
