Fix header leak?
Keeper
While I was out driving the bucket yesterday, I noticed that it sounded different, had a nice tick.
I tracked it down to a leaky header, but it not the gasket :( its leaking where the pipe goes into the flange at the engine.
You can see the soot in the pic, around the front pipe:
Can I just take the header off and weld from inside? I would really like to save the coating as much as possible.
Keeper Do you have a tig welder ? You most likly wont hurt the jet coating.
The only way to fix this is to weld it. Welding will entail removing the ceramic coating. I have had good results using a bronze filler rod with the tig, heat input is a bit lower, the bronze filler flows nice and is more crack resistant as a repair. (note, I mean bronze as opposed to brazing rod, which won't work worth a damn as the zinc boils out). VHT paint, at least make it look as though someone cares enough to try to neaten it up :(
At a car show a young lady decided to stand on my passenger side turnout to have her picture taken. Needless to say I was looking somewhere else at the time. The welds on the front and rear pipes broke at the flange so I took the headers off and tig welded them from the inside. It worked fine but the Jet Hot coating didn't survive.
I have a friend who's turnouts pointed downward a little more than he wanted so he put a floor jack under the end and tried to bend them up. Now he gets to weld his as well.
Thats exactly what I did. The drivers side survived the procedure!
When I build my exhaust system I weld mine on the inside. It just needs to be clean metal where you are welding.
Go for it what ya got to loose.
I think I got it. The tube was cracked completely around the pipe. So I switched the welder over to some .25 wire and put down about 100 tacks around the pipe. Ground down the welds and then I took a flashlight around it to see if I got it all.
Looks good, tomorrow I will put it back on and test it out.
