PeteT
I'm still playing around with different ideas while I wait for my engine to arrive but I've a couple of questions, hopefully simple?
1. Can I turn a Vega box round (so its on it's side) and use it for side steer instead of cross steer? (Thinking right hand drive here) It seems to move in the correct direction, just wondered if there could be any problems (are they filled with oil for example?) I would probably need a pitman arm with a bend in, are there similar spines on different types or are they all different?
2. I've got a total performance axle with hair pins but I want to use four bars instead.
Do I need to support the rod end on both sides i.e. get a second bracket welded to the axle to fix to the other side. Likewise should the chassis end rod be fixed both sides. I've seen some with a large washer and single sded mounting.
The four bar kits seem to support both ends but are a lot thinner material.
Thanks in advance. Pete
