When people report, they set the float levels, adj the idle mixture, etc, etc. You can only hope they are doing it right. Holley specifically states the float level on the primary bowl is just below the site plug. Key word there is below. When shooting for perfection, these things matter. Blipping the throttle in neutral doesn't tell me much. I have never been able gain anything by pushing the clutch in, blipping the throttle. I would not worry or pursue that as an issue. Difficult to tell, but your idle sounds high. pv vacuum reading would be done idling in gear for an auto trans. I would call that 15-16 inches, 7.5 ideal. Your discovery of a better idle mixture adj relating to less hesitation, is discussed in the Holley tuning site, you read earlier, supporting how all the systems overlap to get a smooth transition from one level to the next. I'll bet that carb won't be far off stock when you get it right. Seems we asked earlier on the 600 carb, what fuel pressure are you running?
