Okay let me back up a touch and explain my madness here.
If I make a change, and it makes no difference in the way it is running, I am changing it back to the base setting. This is just for me to try and keep things straight so I do not just keep chasing my tail making wholesale changes.
Couple of other comments I have made and explanation.
The ported vacuum test was to see if the ported vacuum port on the carb (the one on the metering block - in case I am using the wrong terminology) was pulling any vacuum while the car was idling. Mine does not, this was part of the testing to see if the primaries were open to much at idle as I would see vacuum at the ported port if they were. (Hope that makes sense) It is capped when its not used.
The transfer slots came from me reading my Holley carb manual (I do have one here!!) and it telling me that I should only have a little square showing on the transfer slot and not over half of the slot showing, so I adjusted the secondary idle to allow me to close that slot up. (Didn't do anything that I can tell)
No idle problems at all, it will idle smooth around 600 or so.
Here is the update for today. I tried your suggestion on the ported vs full advance, here is what I noticed, the idle had to be raised when I switched it, the idle is more lumpy (not a bad thing) but it ran exactly the same.
I really need to have someone ride along and record what I am trying to bring across in this thread.
Here is the exact scenario:
- cruise at 30MPH (1500 or so RPM), if you hammer the throttle, it hiccups then goes
- cruise at 30MPH (1500 or so RPM), lean into the throttle at medium speed, it will stumble a bit then go
- cruise at 30MPH (1500 or so RPM), slowly throttle up, it throttles up fine.
- hammer it from idle, no hesitation it will spin the tires and run
- If I am playing with the transmission in a lower gear keeping the RPM's up, there is no hesitation no matter how I play with the throttle
I know this is frustrating, I am trying my damdest to explain everything I am doing.
