dwsatt21
This is the structure I have under my seat. Supports the seat and the passenger side has my fuse boxes and OBD port. The right is my battery box. I just painted it so with this Houston humidity, I’m going to wait a little bit for the paint to fully dry before putting the battery in it.
This is the battery cable and through panel connections I have. For the life of me, I can’t believe I need that big of a cable, but all the reading I have done says I do.
Tranny cooler mentioned earlier. Hope it works. If not, I have a plan B.
My cup holders. If you look closely at the face metal, you can see I warped it. I’ll address that later. For now, it works.
![Headlight wiring (15) [640x480] (2015_11_13 11_07_31 UTC).JPG Headlight wiring (15) [640x480] (2015_11_13 11_07_31 UTC).JPG](https://tbucketeer.com/data/attachments/14/14983-9145ca1f93bc7b76b0a051475e6140e5.jpg?hash=kUXKH5O8e3)
![Headlight wiring (16) [640x480] (2015_11_13 11_07_31 UTC).JPG Headlight wiring (16) [640x480] (2015_11_13 11_07_31 UTC).JPG](https://tbucketeer.com/data/attachments/14/14984-48a72df79decbf21bcfed7d31e66fb5a.jpg?hash=SKct953svy)
![Headlight wiring (12) [640x480] (2015_11_13 11_07_31 UTC).JPG Headlight wiring (12) [640x480] (2015_11_13 11_07_31 UTC).JPG](https://tbucketeer.com/data/attachments/14/14986-a11beafcaa3f80c30b6dffadc7e29e0e.jpg?hash=oRvq_Ko_gM)
