AndyMenon
Hello my friends,
I have a PC-91 coil. I plan to mount it on the inside & under the dash on the passenger side, and then run the wires thro' a hole in the firewall. Will this in any way cause electro-magnetic interference with my Electronic gauges?
The intent is to keep my firewall (which btw is fibeglass) looking as clean as possible on my T. I'll be cutting a wooden backer board to fit under the dash, and mount the coil and the fuseblock of the wiring harness and then run the wires from there.
Tips?, Ideas?
Thanks much!
Tips?, Ideas?
Thanks much!
