Gary, a bit of advice: many of the electrical problems I've seen involve bad grounds.  I don't use the frame or engine for grounding.  Each load and sensor has a ground wire that runs back to a bus on the wiring panel, and the bus connects to the battery.  Some of today's fancy parts, like EFI and fan controllers, are especially sensitive to any electrical noise, and there can be lots of noise in the frame and engine.  Unfortunately some sensors (water temp, oil pressure) have only one wire and depend on the engine for ground.  If you put Teflon tape on the threads you can get little or no ground and the sensor gives a bad reading.  I use 2-wire sensors if available or add a ground wire to a 1-wire sensor.  Or use mechanical gauges and avoid the sensor problem.  I also like mechanical gauges for the 270 degree sweep instead of the 90 degree sweep of electrical gauges.
		![wiring coming along (12) [640x480] (2015_11_13 11_07_31 UTC).JPG wiring coming along (12) [640x480] (2015_11_13 11_07_31 UTC).JPG](https://tbucketeer.com/data/attachments/10/10165-45e01bf01cab133929a8f69a7e7c9b48.jpg?hash=ReAb8ByrEz)
		![fuse box wiring (10) [640x480] (2015_11_13 11_07_31 UTC).JPG fuse box wiring (10) [640x480] (2015_11_13 11_07_31 UTC).JPG](https://tbucketeer.com/data/attachments/10/10171-de8d1a477492adae60d6cdb15a2ce99b.jpg?hash=3o0aR3SSra)
![fuse box wiring (12) [640x480] (2015_11_13 11_07_31 UTC).JPG fuse box wiring (12) [640x480] (2015_11_13 11_07_31 UTC).JPG](https://tbucketeer.com/data/attachments/10/10172-dcf621137758d8a74b290513a1df307e.jpg?hash=3PYhE3dY2K)
		 but I'm correcting that now, it's now mounted inside under the seat and exits under floor and up through a hole near the foot well are. The engine controls will exit near trans under firewall as nothing is mounted on it. I have a buss bar for grounds under dash along with a relay panel.
