cmcdanl
That too... First let me say, I am on a very tight budget, so I'm working with what I can get. I went with this spring/ coil over set up because it was cheap. The spring is too soft to be used alone, so I added the motorcycle shocks. I ended up changing my rear suspension design when it came time for it. I made the frame kickup in the rear kind of small because I was planning on running a spring over the axle set up. When I mocked it up for that, it was way too high for me. I just don't care for that stance. So I made the spring behind mounts which lowered the car where I want it, but now there isn't a whole lot of travel between the frame and axle. So I want it to be stiff, so it doesn't bottom out, but I also don't want it too stiff. Luckily, there is a lot of adjustments I can make to find the sweet spot. The coil overs are on the softest setting right now. And if I remember correctly they have around 6 adjustment points to make it stiffer. Then if it's too stiff at the softest setting, I'll take out some leafs. I think it will work out fine. I will just have to make adjustments when I get the car on the road and see how it rides.It doesn't look like there's too much room between the coils either for travel. They may end up bottoming out. Like you said, you'll find out...
Why did you use coil over instead of just shocks?
Also, just to give you an idea of what the cost difference is... Normally a coil over setup could cost between $300 - $500 for the coil overs. Or for a leaf spring setup, $200 - $300 for a rear leaf spring and about $60 for rear shocks.
I paid $40 for my Harley coil overs and the leaf spring I took off of the front axle so it was basically free.
