smokeyco75
Ok not much to update but I did set the engine in the frame to get an idea of how things will look. I still don't have a transmission to mock up with yet so I guessed at where the back of the motor will sit for now. (I'm tapped out from Christmas) Problem is I only have 4 and a half inches from the bottom of the oil pan to the ground. I need a transmission to be sure of that. Meanwhile does anyone have a pic that would show where the back of there engine sits in relation to the frame rail using a Ron Pope frame with chevy power? Once I verify this I can verify frame height is correct and begin building my front suspension while I look for a transmission. I will be using the traditional leaf spring and hairpin design but it will be slightly different than normal. Very similar to how Meangreen's son's car is built. (It is a Model A Tudor sedan with a suicide front end)
The final look of this car should be pretty cool although nowhere near unique. Since I began this build my vision has changed partly due to budget and partly due to some great ideas I have seen here. Some things I am still undecided on. I'm sure I will change my vision at least one more time before it hits the streets, lol. Anyway for all the folks interested in my build I thank you. To all who have offered guidance and suggestions I thank you as well. This really is the best site out there and some of the best folks I have never met.
