Found a different kind of Dana 44 diff cover that will allow for some more clearance with the rear mounted calipers:
I even think the style of the diff cover fits the build a bit more too
Back on Bucket #1. It has developed a couple of issues.
A couple of electrical gremlins popped up. One in the form of intermittent crank trigger signal loss, the other a random cylinder misfire that I could physically change by moving wires.
Also, both valve covers were dripping a consistent steam of oil onto the headers, I figured while the valve covers were off again I can dial in some new cam timings to test.
I've been wanting to get the fuse block, relays and wiring out from the under the dash for a while now. The car has several years worth of iterations, changes & tinkering of EFI components, wiring, lighting and electrical changes. It's time for a clean up, and I know I can make the wiring cleaner and simpler this time around.
The EFI controller, relay/fusebox and a constant duty solenoid as a main relay will all be mounted on the lower section of the steering mount arm off the frame and not under the dash anymore. The gauges and switches mounted in the body will be able to disconnect via deutsch connectors.
I may take this opportunity to install the Pi-Dash and touch screen into build #1 that I was going to use in build #2
