That is a beautiful engine. I admire your skills. I can barley do anything to an vintage chevy engine way above my pay grade.
I'm thankful there is no demand for these engines and there are so many of them produced, I pick them up for a couple hundred bucks and you see I don't tear into the rotating assembly. All the shiny new bits are Ebay & Amazon.
I think we are witnessing an epic build thread here, folks! For me this ranks right up there with Choppinczech's roadster body build. One for the archives.
I agree with @Spanky - Love watching this build coming together.
Way above my knowledgebase to be able to do this!
Mykk, I notice that you have the spring clip over ball joint at the throttle bodies. The inner arm connections look different.
Can the inners snap off easily to pivot out of the way to service the injector rails? I guess the whole linkage pivot might not allow the rails to lift up and out.
You are correct. I even made/modified new rods this morning using old boat turnbuckles.
If & when I need to access the fuel rails I suppose I could unclip the rods from the throttles and remove the bellcrank pivot bolt then remove the whole thing.
Are the holes in the bell crank for adjusting the ratios or just cosmetics?
