neutral safety switch on chevy 3 speed
jjsticks
I was told i need a n/safety switch hook up on my chevy 3 speed trans.any ideas on how hook one of these bad boys up? any drawings?jj
open up the start circuit to the starter sol. and loop it through the switch. in Park or neutral sw is closed and shazam it starts. In gear sw is open and voltage stops at the neu switch nostartie.
I can't see one on the car.shifter was hand built.i guess i need to see if theres a spot on the linkage.or pedal mounting.
my ford pu has a auto shift release on the brake if nothin else add a psi sw to the brake sys and loop the start through it. When you are on the brake it can be started.
