Lowrollerchevy
title says it all, pretty simple stuff here
allows you to cut the frame, slip the tube into place, then wrap the top and bottom of the frame rail around the front of the tube
the top and bottom of the frame will have to be trimmed slightly as they are a slight bit longer then needed to properly wrap around the tube
by the time your done welding you have 180* of weld on the outside of each rail, 360* of weld on the inside of each rail, and 2" across the front .... should be pretty secure in there![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
