Pressure Modulator
Johnny
I'm going to be using a turbo 350 tranny, and when I hook up the pressure modulator is it okay to use the steel line that would be on an old Camaro? Or, will any car that used a tb350 work? Steel braided hose, or just rubber hose????
Thanks
If you're talking about the vacuum modulator, yes you can use the steel tubing. That's how mine is set up and it works fine. I used 3/16 brake line with rubber hose connectors at each end.
I used the braided line for looks so you can do whichever way you like.
Anything is fine so long as it does not collapse under vacuum.
Gerry
