I found a new respect for pad and shoe compounds last summer. That can really make a difference!
I was locking fronts on grass or loose surfaces the first year I had her.
Finally added a front Proportioning Valve to limit the fronts slightly. (My rear wheel cylinders were already max sized.) Worked great with just a slight adjustment from wide open.
Anyway...my front pads were squeeling a little so I bought new pads at the end of the season.
Semi-metallic high quality ones.
Brakes were much harder and not effective last summer! I opened the PV fully to allow full pressure to the fronts again. STILL not a brake I felt good about.
I continued to drive it till summer was over and then I sanded and reused the old pads this past winter.
Brakes now work great again...and I had to slightly limit front pressure with the PV just like before.
I believe the GOOD pads are actually old school organic compound.
Seems like the semi-metallic pads might actually be designed for long wear and not short stops!
Good brakes make for a much bigger smile out on the road and I like long runs.
