tfeverfred
What are you guys running? I had read of some defective units, so I'd like some advice/knowledge on some good ones. Thanks.
I thought you were going Disc-Disc Fred.
I'm running Wilwood units with no problems.
As far as price goes, the wilwood were overall cheaper for me to buy than the speedway brand. The. Willwoods came with the adapters, the speedway ones so not. So when you put the whole package together, the speedway ones cost a bit more.
The master cylinder in some cases have them built in.
What you want avoid is adding the residuals on top of the master with the residual inside.
If its a Disk -Disk master like I did you just add the residuals for the drum brakes.
I found that allot of the more cost effective masters are disk -drum with the residual built into the drum side.
I'm not using any, and have no problems. Drums in rear, discs in front; adjustable proportioning valve on rears. Good pedal feel and stops on a dime. I have a pair of RPV's if you want 'em. Give me a snail mail address & I'll send them to ya'!
Offer still stands. I just need an addy . . .![]()
