RPM bolt on batwings - need some info
trogdor
I'm looking at these bolt on batwings from RPM. I need some info about the perch pin used to mount them. Specifically, what size bolt/pin does it need to be, where to get one, does it need to have taper/cones on the end, etc. If anyone has experience using these I'd be interested in hearing more. Thanks!
Ok thanks. You have those same batwings from RPM?
My batwings came from Pete and Jakes, I don't know where I got the bolts, but I would imagine that since either set of batwings go onto the same Ford solid front axle the mounting would be the same. Nevertheless, I think Amazon would take the bolts back if they didn't fit.
