PeteT
Still at the mock it up and see if it will work stage.
Got myself a Posie quarter elliptical spring kit from Speedway and I think it may work but I'm not sure on how to set the ride height and shackle angle.
What should the shackle angle be with no load and at ride height? I've seen pictures with the shackle vertical but this doesn't seem quite right to me.
Also I'm not sure how much they will compress once I get some weight on the front. I'm trying to avoid using the big adjuster bolts that come with the spring kit and mount them under the chassis rails. I've got the chassis at 8" above the ground so haven't got a lot of room to play with.
The only way I can see is make the chassis, fit the engine and then clamp the springs on and try it, but then I'm totally committed if it doesn't sit low enough I've got some major cutting to do!
Has anyone used one of these kits that can give me any clues on setting up.
Thanks in advance. Pete
