Its about to get even better
Well since we are discussing car suspension, and not tool and die making, Brucer, how about we stick to info that is relavent to that ? Tensile strength has very little to do with this. Most all fasteners used in the suspension of the type of car we building, are in shear. And a lot are single shear at that. Grade 8 vs. Grade 5 is the same as chromemoly vs. Mild steel. One is more forgiving that the other. Mild steel will bend in situations where chromemoly fails. Same with the grade 5 bolts compared to the grade 8 bolts. And in a suspension system (as well as steering systems), that ability to bend, rather than break, is more desirable. Look at these pictures, specifically the bolts holding the front bars to the frame.
This is a typical set up. Whether it is a four bar, radius bars, split wishbones, they are almost always mounted in single shear. The constant pounding those fasteners take, will break a grade 8 bolt. But only bend a grade 5. That pounding is the vibration I was talking about. Maybe vibration was the wrong word to use. Flexing is probably the proper term. It is just not vibrating, there is force behind it also. That flexing will work harden the steel. No heat required. Dont believe me, go grab a piece of metal, or as I learned with as a kid, a coat hanger. Start bending it back and forth. What happens ? If you do it fast enough, it generates its own heat... And it will eventually crack.
Here are some quotes to support this found thru a google search...
"Fatigue in a fastener can cause sudden, unexpected failures. A fatigued fastener can fail even when loads are below the strength of the material due to operating under constant cyclic loads. Fatigue strength is often defined as the maximum stress a fastener can withstand for a specified number of repeated cycles before it fails."
"One of the issues with Grade 8 bolts is that there are some areas where you really don't want to use them," says Doc Hammett, Totally Stainless. "If there's a cycling load on them you could start to get into trouble."
There is no doubt grade 8 bolts are stronger than grade 5. But does the strength difference matter in this application ? A 1/2-20 grade 8 bolt has a tensile strength of 150,000 psi. The same grade 5 is 120,000 psi. Shear strength is estimated at 60% of tensile strength. The shear strength of a 1/2" bolt is approx 14,130 psi. Do you really think the rating of that grade 5 is not enough to hold up your 2000# car ? If you dont, going up to a 5/8-18 grade 5 would be better than going to a 1/2-20 grade 8. More strength and more forgiving. 17,662psi for the 1/2" grade 8 vs. 22,078 for the 5/8" grade 5. (assuming my math was correct LOL). And who is to say a 1/2" bolt in this app isnt overkill already ?
A question I always have for the guys that swear by grade 8's is why stop there ? Why not L9, why not air frame bolts ? I believe the simple answer is the others are not easy to get. A grade 8 is available at your local, home depot, lowes, ace hardware. But does any one stop to question the quality of those grade 8's ? NO. We all know the chinese are good for importing low quality products. Don't you think thier fasteners could be the same ? There steel is known to be poor quality. Now what about the quality of grade 8 vs. The aircraft hardware ? A lot of high dollar race cars use aircraft hardware. Not grade 8's. So is it safe to assume it is better ? I think so. The tensile strength of an air frame bolt is similar to that of a grade 5 (the online sources I found for AN hardware says 120,000-125,000 psi). The same theory of it is better to bend than break is used there too.
There is a lot of good advice on the internet. There is also a lot of bad advice. The problem is separating the two. The worst advice, can sometimes make the most sense to someone who doesnt have any knowledge on a subject. Do your own home work, spend a little time on google doing searches, and apply some intelligent thought to all you read.
