old round fart
Good work Fred. It won't be long now. Looking foreward to seeing you on the road again. I was unable to find numbers on my chassis. Are they on the top or bottom of the frame?
old round fart said:Good work Fred. It won't be long now. Looking foreward to seeing you on the road again. I was unable to find numbers on my chassis. Are they on the top or bottom of the frame?
tfeverfred said:I had disconnected the line for my oil pressure guage at the engine block and forgot to plug the fitting. First two cranks and oil sprayed everywhere.![]()
joes23t said:Just had a chance to follow up on the build and I think its great the additude and the progress looks and sounds good. My loose nut story is (you have to check the muffler to the headerclamp bolt) Durring the see how they look stage I foregot about it and headed down the road. Got on the high way to about 70 and blew it off. Made the honest attempt to look for it then (THE PLUS SIDE) I was able to talk the wife in to a new set of pipes and muffs. GOOD JOB AND GOOD LUCK Joe
