An update with PIC!
First off, thanks for the birthday wishes. I don't feel like 50, so it's not that bad. Oh, the AARP stuff started coming about 6 mounths ago.:rofl: I ignored them..... for now.
Now, on the the important stuff. Here ae the pics of where I am as of today. In the first pic you can see the shock bracket and headlight bracket that RM made for me. They fit ike a glove. I used the Monroe #5752 shocks and cut the top sleeve off, as I had read about on a thread here. I gave Miss Fortune the old "jump on the spring perch test" and they will be more than adequate. Ignore those nasty looking bolts, I'll have grade 8's on her tomorrow.
Here's a pic of the steering column installed. I still need to mount the support, but that is a minor detail. This evening after work, I installed the headlight brackets and headlights and was going to call it a night, but I just HAD to mount the signal switch and tach. I just had too.:rofl: I'm not sure if you can se it clearly, but the B&M shifter a friend gave me is a good shifter, but the cover for it is way too large and it will be in the way of my foot getting good placement on the gas pedal and we all kno how important that is. So, I'll either make a smaller cover for it or get a more practical shifter. We'll see.
Here's the view I hope to have when I take her for a spin VERY soon.:sofnny:
Now for her good side. This is not the radiator I'm going to use. It has a leak and a Mustang radiator is cheaper than the estimate I got to fix it. I may fix it later, as it looks to be a 4 core. I'll see. The grille is just placed on because I just love the way it looks.
So, that's where I'm at. Tomorrow, I plan to hook up the throttle cable, tail lights and hopefully reconnect all the wiring. Depending on how long that takes and the weather (it says rain and cold for tomorrow
) I may get a test drive in. Fingers are crossed!
