So my build is underway, lakes modified inspired 23 bodied car. I have lasered and formed my own channel frame from crs sheet at work. I have a speedway medium arch rear spring that will sit in a model t rear crossmember with toyota 7.5 axle behind. Front is forged 26" monoleaf that will sit under the front crossmember with 4" drop axle mounted in front of the spring and crossmember. Wheelbase will be right at 90", steering will be sprint car style. guesstimated weight of 1400-1500 lbs soaking wet with a mostly aluminum buick turbo v6, th350 and me in the drivers seat.
My questions for the suspension guru's here are;
springs, will they need to be spread? does not seem i would need to preload much?
shocks that will work best?
radius rods? 4 bar? length?
Basically i am wondering what setups will work best with a short light car? I have given this alot of thought but i would love to get some opinions from some experienced sources.
