Weekend Update . . .
The weather cooperated and after a trip to the hardware store to replace some tools that seem to have gone AWOL, a few bits of hardware, and a nourishing breakfast at McDonalds, it was day 2 of the 632 adventure.
With the engine now sitting solidly on the stand with the flex plate attached, I dropped in the starter, but had to remove the shim so that the pinion would engage the ring gear to the proper depth. With that done I checked the tooth depth with a big paper clip, and it was fine.
With the starter secured, the fuel pump was next, . . . . I'm running a mechanical, Holley's biggest, which went in without issue using an ARP pushrod.
The front drive assembly was another matter . . .
While the water pump went on without issue, the bracket that mounts the alternator to it doesn't seem to be the right one. . . . and the belt seems too short . . .
Or . . . Blueprint Engines machines their tall decks to use standard deck accessory bracketry. . . .
Which would be my luck, since I ordered the tall deck front accessory kit. . . . anyway . . .
The new pulleys all mounted up fine and I really like the look of the 8 rib serpentine belt.
Took the opportunity to replace the original balancer bolt with the new ARP one before mounting up the crank pulley.
I'll call tech support this week and get it sorted out, overall . . I really like the mid mount alternator position . . shows off the heads and valve covers nicely.
I was a little disappointed that there was no vacuum port as it arrived, and no provision for one either.
Since I have power brakes and need a vacuum switch to allow the lockup converter to function properly, I bought a 1" carb spacer and drilled and tapped it along the rear for some vacuum connections. The distributor has a vacuum advance, but I'm not yet decided about using it.
I had to make up some seriously longer carb studs to accommodate the spacer and extra brackets for the throttle and return spring assembly and the regulator mounting. Used some 5/16" stainless steel all thread with sst hardware and it all works like factory stock.
As I was getting to the last few things on my to-do list, I filled a filter with oil and added 7 quarts to the engine, spun the oil pump with my handy dandy primer tool, and put the distributor back in.
The oil level on the dipstick is right at the full mark, but it's a bloody mystery to me as to where the dipstick is supposed to attach to at the upper end . . . There's a bracket there that just waves in the breeze and the stick sits right in front of an exhaust port . . .
Another thing to ask tech support about . . .
Overall, it was a very satisfying weekend with a lot of progress, with almost everything wrapped up until a couple more parts get here,
I cut a little piece of wafer board from the original crate and fitted it to the engine stand so I can put a battery in place to see how it cranks.
![Batttery Base 1r.jpg Batttery Base 1r.jpg](https://tbucketeer.com/data/attachments/11/11994-a6aaf071384a67c0022fc3366a691b6f.jpg?hash=pqrwcThKZ8)
