I have a seven wire after market column mount turn signal switch , I wired per the direction sheet and the signals do not work. One of my questions why do you need two flasher relays one in fuse panel and the switch calls for one. I have the wires to the flasher just as they call out,I have a wire from the turn signal going to brake switch and the other side of the brake switch going to batt. The turn signals and running lights do not work and they have dual filament bulbs. Any help woyld be appreciated
