This weekend I did some experimenting with a T that has a frame built from the plans I have posted in the Tech Articles here.
We swapped the bushed ends on the ends of the hair pins for heim ends. Although there didn't seem to be a problem with the bushed ends, I have always wondered if the heims wouldn't work better. As a result, we found the steering effort to be less with the heims on an unequal road surface. I don't think I would go as far as to say the ride quality was improved. At least I didn't notice any change during a 60 mile test drive.
The parts used were ordered from Speedway.
Heims...#175-0126
cone spacers...#546-4110
It should be noted here that a washer should be installed on the outside of the heim as a safty item incase of heim failure. We used a cone spacer for the washer to increase the articulation of the heim.
Heims...#175-0126
