As a Tie rod end, what they were designed for, there is not much of any side stress, just straight back and forth pull and push. Now, attached to the rear of a hair pin type of radius rod, they is now more than just back and forth pressure on that joint, which is called side stress, any time the car turns, what is holding the complete front end in place??? only a shackle at each end of a spring, and those two Tie rod ends... Can you now see the side stress? As that whole assembly wants to twist sideways, those ends hold a lot more pressure than you will ever know... I have repaired way too many rods with the wrong type of ends on Radius rods.. Now a 4 bar set up is totally different, only the shackles are holding the front end from moving sideways, and the straight push pull radius rods links, hold it from moving forward and back, except the amount of arc, created by the length of those links, that is why it is best to use a shackle 1/4 inch wider than the spring or the mount, as this will allow the movement of the axle back as it moves up and down. That stops that side stress, other wise, the spring will be put in a bind, the shorter the radius rod, the greater the bind. SO, with the ends of the Radius trying to get loose by pulling from the out side (not back and forth) those ends are not made real strong for forces from that direction... I want a good (grade 5 or better) through bolt with a heavy duty washer (to keep things together if failure should happen) and a good nut on the back side of a strong frame mount, holding my front end in place, Thank You, just me, yes? :welcome:
