Welcome to Our Community
Sign Up
Dismiss Notice
A Bit More Progress
Discussion in 'Bodies' started by choppinczech, Feb 28, 2016.
  1. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Thanks. Is the side of a Model A undercut as much as a T body?
  2. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Thanks. Is the side of a Model A heavily under cut like these bodies?
    I'm hoping to have only half of the upper hinge's barrel exposed. The bottom will be out there wherever it has to be.
  3. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,791
    554
    Gender:
    Male
    Occupation:
    Retired
    The hinges I used were concealed. None of them showed when the door was closed. The difference is that with the concealed hinges the pivot point actually moves with the door.[​IMG]
  4. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Interesting. I'm trying to visualize how these would work.
    Which end attaches to the door?
  5. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    I've pulled this off the net a long while back.
    The guy was making these for AC Cobras. They look to be about 6" apart?
    kcline40 likes this.
  6. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    I might be able to something like this if it were mounted high.
    @RPM
    Ron, could you cut these out of 3/8" plate?
  7. RPM
    RPM
    Expand Collapse
    Administrator
    Staff Member Forum Sponsor
    Oct 16, 2007
    5,072
    656
    Yes we can make those. We actually make something similar to those already, for a company and they use them on their Willys coupes, they build.
  8. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    I'm gonna give this a shot.
    4" wide hinges based on those designs. Mounted high on the door.
  9. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    As long as you have room inside for the hinge, it should work out. That design basically changes the pivot point of the door, sort of like the swing away handicap accessibility hinges do. Cool idea!
  10. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    You could make those with flat stock. As long as you used a template or something to allow repeatetive results. You may want to consider hardening them after fitting them. I could imagine them being suseptical to damage if someone put too much weight on the door when open.
  11. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    Draw your door & jamb in the open position , then in the closed position , then play w/the hinge shape & see what works [what is the best compromise]..
  12. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    This mono hinge is working. Here's what I planned out.
    And an actual cut-off piece of the profile.
    After three tries (three week ends), what a relief to mock it up and finally have no bind.
    It's all just tacked and hot glued together for now. There's lots of beefing up to do.
    I wanted to make sure it even worked before I put a bunch of time in it.
    This plate will attach to a steel frame work.
    cooter, EX JUNK and kcline40 like this.
  13. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    Awesome! Great Job! That is going to be a hinge worthy to be on your ride.
    choppinczech likes this.
  14. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,214
    1,182
    Gender:
    Male
    Occupation:
    Retired
    I just knew this car was not going to have exposed hinges! Good job Chop!
  15. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    Very Slick !!
  16. Dan Noecker
    Dan Noecker
    Expand Collapse
    Feb 25, 2015
    69
    29
    Gender:
    Male
    Your body work is most impressive. Job well done.
  17. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Thanks guys. You might have noticed, my confidence was shaken for a bit when nothing was working.
    When I cut these door openings, it was game on, no turning back.
  18. rubicon
    rubicon
    Expand Collapse
    May 28, 2007
    859
    254
    Gender:
    Male
    You are a genius. A real problem solver. great job.
  19. Gerry
    Gerry
    Expand Collapse
    Dec 31, 2009
    2,644
    600
    Gender:
    Male
    There you go.:sneaky:
  20. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    The best way to learn how to swim is jump in the deep end! Lol... I had faith in you.
Share This Page
SSL Certificate
