sampanjohn
Car is new 27 Spirit. Brake pedal is hard but the brakes work very poorly. Master cylinder is Corvette manual disk/disk, bench bled, 6 to 1 pedal ratio. Front brake calipers are 70's GM intermediate, rear calipers are 2000 S-10. Pressure at front caliper is only 300 psi so we put the gauge directly on one of the master cylinder ports. Still only 300 psi.
Any help is appreciated as I am ready to drive after 2 years construction once this "minor" problem is solved.
Thanks
John
Thanks
John
