I agree that the rods should be tied together, but the only way that shock could break the clevice is if it is bottoming out. The travel needs to be controlled (bump stops) or you will continue to have load issues. A shock is only to control travel, not hold up the car. That is a leaf spring or a coil springs job.
From looking at the pic, the clevis appears to be under constant fatigue and vibration, especially with the lever effect. I could imagine it failing from metal fatigue without bottoming out, but that would explain it. What is it made from? What grade, etc... It could be a bad part, or it may just need to be stronger or re designed. Does the clevis pivot where it meets the shock when it travels, or just remain horizontal? Nice car, by the way.I think the up travel had to do the damage. Should have been able to tell by looking at the clevis threads which way it was broken. The car would have almost have to be air born to break it down wards. Just my guess.
Lee
Jayson lives in Louisiana. My T Bucket becomes airborne on I-10 locally when coming off overpasses at 70-75 MPH. Any slower you are a traffic hazard. The back tire will chirp when they come back down.The car would have almost have to be air born to break it down wards. Just my guess.
