My First T-Bucket Build
Yes it is fully depressed, and it's not the caliper that is in the way. It's the caliper bracket. I can move the caliper back and forth so that's not an issue. Take a look at this picture. The brake pad sandwiches between where the two arrows are.
Perhaps it requires a spacer behind the inner bearing to move the rotor out. Would you will have room for the cotter pin thru castle nut?
Are these the cast brackets from Speedway?
Yes they are the cast brackets from speedway. They came in the disc brake kit that I bought from them.
I hadn't thought of that. Do you know if anyone makes a spacer for that or is that something I would have to make?
On your first post on the brake issue (#252), you state you are having problems on the driver side brake. Is the passenger side installed and if so, do you have the same issue? If no issue on passenger side, start measuring everything to find the difference. Wouldn't be the first time incorrect or defective parts were included in a kit.
Pure speculation here. Is there a chance that the paint/powder coating is to thick where the two surfaces meet, holding the caliper bracket to far out. I always remove paint or powder coat on places where two things bolt together. If when bolts are tightened, it compresses paint or pc, and they can cause looseness later on causing problems. I know when I first started doing pc on harley frames, the engines would loosen in the mounts if pc was not removed. Not sure how much you are off, but that could possibly be your problem..??
I am using just about the same tank in my roadster. I wish I would have welded in a place for a gauge before I put gas in it. It gets about 25/30 mpg, but it would be handy to have a gauge.
Did you figure out your caliper problem? Curious to see what you found.
I used a conventional 'hanging' unit for my 10 gal tank. Just cut a hole in the top of the tank, and carefully bend the mounting plate for the sender to conform to the shape of the tank. A neoprene rubber seal and a little black silicone seal it up. Since it's on top of the tank, no leaks!
Been a while since I posted an update. I have been working on brake lines. I was having a lot of trouble making a good flare after trying a couple different tools, so I bit the bullet and just bought the professional brake flaring tool from eastwood. I should have just done that from the start. what a difference that made. After I got that tool it all came together pretty quickly. So now my brake system is done. The bends aren't the greatest but I think I did ok for my first time. I also made my fuel line and mounted it. Next up is to put the body back on and start wiring.
Lookin' good, danl!:thumbsup: BTW, the rubber sleeve on the front lines needs to be located where the brake line may rub against a suspension component, and can be held in place with a wire tie.;)
They do a black chrome powder coat which is really nice. Maybe for the tank......
Thousands of colors now in powder coat, let your imagination go.
Having the right quality tool for the job makes a big difference, especially with inverted flair fittings, all things tubing, really. I recently invested in a new hydraulic flair tool with all of the dies to create every possible variation to date, this was due to replacing fuel lines on my GM truck, and the quick disconnects that they use to connect vinyl lines to steel and filters. I wasn't happy about it, but it is a cool tool. Mastercool is the brand, if anyone is interested. There are also some decent tools for working with the vinyl fuel, vapor, vacuum line, and its resistant to all chemicals, the heat worries me though.
