No standard, only your personal taste. Mine are 15x4 and 15x10.
I like the stance on your car, Youngn! nice n low...
What rear uses 4.25 bolt circle? Never heard of such! John
18x5 and 20x15View attachment 8566 View attachment 8566
What kind of gas tank is that? I like it!
It's a 4 bolt 4.25 pattern..if that woukd help .from an 88' Thunderbird Turbo Coupe. But it's the same Ford 8.8" axle as used in the 79-04' Mustang. I went with this axle because it is wider than the Explorer units. I need the extra width because the body I have is 6" wider than most, and with the bobtail style I'm going for the body will be set back far enough that the widest part of the body will be between the wheels.
You could easily change those axles for very little money to get 5 bolt if that would help your wheel selection. You just need 2 Ranger or Aerostar driverside axles and brakes.
