Are you sure you'll need that many leaves in the front spring?
What you are depicting is basically what I'm running on my car. It is an adjustable four link with a wishbone locator.Lot of info on the net.
But here is a link to an easy explanation.
Tuning 4 Link Rear Suspensions for the Drag Strip
And here are the calculations for my setup. I targeted a neutral setting.
A lot better traction and handling.What you guys are doing is way above my pay grade. What is the advantage of the 4 bar set up?
A couple years back I spent a LOT of time on that and my CAD program coming up with all kinds of suspensions for my build. In the end I'm using the triangulated 4 link arrangement that my Ford 8.8" rear end came with. The only bracketry that will need to be welded to the axle is the lower air bag brackets.Lot of info on the net.
