whaAround last Thanksgiving I started working on my deck lid.
The first step was to lay it out and add brackets with clecos so every time I took it off and on, it goes back in the same place.
Then made a backbone to hold the lid's shape. Flipped over, it supports the lid during all the work ahead.
And cut.
Then made a steel brackets to hold the BMW trunk hinges and latch.
Then started this drop in mold. It was held in place with the same cleco holes made before.
After weeks of work, it ended up like this.
With the mold fastened in place and everything flipped over it was time to lay up.
The mold popped out much easier than I thought it would. I was expecting a fight.
What's the secret for attaching the steel to fiberglass? I need to attach some brackets in bed with hood pins to hold deck lid down. I have failed on my first attemptAround last Thanksgiving I started working on my deck lid.
And cut.
wha
Chop, your craftsmanship on your build is only exceeded by your ingenuity. I really enjoy watching your build come together.
Stainless Steel?
That would almost have me thinking about a 'fancy' front plate for the engine and loose the trad mounts...
Thanks Jim. I stole this idea from these guys.
How it Works - icengineworks
They use the snap together blocks. I'm using my own marked templates. With this method there's no real measuring or angle finding.
