fletcherson
Coremat is a subtrait that allows resin to soak in and makes a very strong, rigid, light weight floor or whatever and it's not prone to rot, like wood products.
Jerry,
Thanks for the information.
Fred,
How did you guess! I may see how it looks off to the side. It does not mean I can't move it. I saw in one of the pictures that a piece of aluminum or similar material is used as a cover for the master cylinder opening. More holes to cut.
I like the coremat floor. I have stood on it with the body on the frame and there is very little give. I weigh 230 lbs as well.
Later,
PaulR
Spirit uses it in some of their body's in the roof, I dont know about the floor. I have heard that it is very strong and will hold fasteners, etc... I have no experience with it personally. I didn't learn about it untill after I began forming my floor with plywood as a substrate and ordered biaxial mat, etc... I didn't want to build molds for a one off project and I am fairly proficient working with wood and felt comfortable going that route.If that coremat is only 2mm thick it will take a lot of layers to make a floor in a bucket.
Fred, can you be a bit more specific as to which dimension you're looking for?
View attachment 11964 View attachment 11965 View attachment 11966
Would that 2mm coremat really be helpful in making a floor that is lighter than plywood?
