Rip VW
Thought I would run this past the members and see what everyone thinks of this setup.
My 27 Coupe Brakes. Lets start up front where I have a pair of 10 1/2 inch rotors with Mid 70's GM metric calipers with 2" pistons. The rear brakes are also disk brakes that match the explorer 8.8 rear end. They are also I believe 2 inch pistons. I have a frame mounted brake pedal with a ratio of 5.75 to 1 and that will be connected to a corvette style 1 inch bore master cylinder. No power booster and at this moment no proportioning valve except a adjustable valve on the rear line only I also do not plan to use any residual valves in the system as per most of the brake articles I have read. I read the article here on Brake setups but there is always questions. I also wonder what people are using for a brake pedal return spring.. Any questions, thoughts, or recommendations? I hope I haven't missed anything in my description but I would love to hear ideas or suggestions. Thanks in advance.. Rip
