When I first built my car and was going to use steel rims, Brian at Total advised me not to use the GM rotors due to the unsprung wieght issue. The explanation he gave me was drawn out, but it made good sence. I ended up using Hallcraft wires and it became a non-issue. On my rebuild, I came across the same problem. Going against what he had told me in the past, I went with the GM setup. I just couldn't see dropping $650 bucks for Wilwoods. So, I got them and all is good. BUT I also have hydraulic shocks instead of friction shocks. Maybe that is the difference. I wonder how the GM's would work with friction shocks? Has anyone tried it?
My thinking is that a heavier wheel/tire combo combined with hydraulic shocks makes GM rotors good to use.
