Indycars
I need some help with my wiring diagrams. Specifically the 4way flasher, how do I wire the flasher and switch. I included a DPST switch (S, T, U & V), I think that's what needed.
Also there may very well be other mistakes, please give my drawing the once over. I tried to label with numbers on the fuse panel and letters elsewhere, the important connections.
The light switch is made by Ron Francis and has the dimmer internal to the switch. Brights are had by pulling the switch all the way out..... see included RF instructions below for more info.
Below defines the steering column connector. Sorry it's not in order, I found the table after I created the steering column icon.
Below is the Ron Francis headlight switch instructions, they maybe helpful.
