Here's some info I found about a GM starter. As I mentioned the pull-in current for the starter solenoid is pretty high for a short time, hence the need for a relay. Even though the high current doesn't last but a few milliseconds, it can damage underrated switch contacts. This is also typical of Ford starters. Even 100 amp fuses can't handle the surge current. That's why you will never see a fuse in that circuit. Instead there will be a fuse-able link in the circuit. A fuse-able link is a short piece of wire 2 or 3 gauges smaller than the wire from the relay to the starter. If you are running 14 g to the starter, the link would be about 6 inches of 18 g wire covered with a flame retardant insulation. This, in effect, is a high current, very slow blow fuse.
Data for a GM PMGR PG260 1.7kw starter.
Max Power: 1.74KW
Max torqw: 21 Nm
Max Amp: 508amps
Solenoid Pull Current: 37.5amps
Solenoid Hold Current: 9.9amps
The inrush current on the starter solenoid is very brief and won't blow an ordinary fuse. I use a 15 amp fuse on my starter:
...one of these days I need to clean up my schematics. Note that I have it wired so the brake has to be on and the trans in N or P for the starter to work. This was prompted after I was standing outside and reached in to start the motor...and it was in Drive. And it started, and the big Hoosier yanked me down to the ground and tried to climb my back. I'll spare you the pic of how I looked after that, but here's my shirt:
Well, seems to be conflicting evidence regarding starter solenoid fuse. Some GM circuits show a 40 amp fuse, some show a fuse link. Ford says always use a fuse-able link. Guess it depends on your starter. Since I have a Ford engine I went with their advice. If you do use a fuse, make sure to have extras and a jumper if they all blow while you're away from home. It's your decision; just error on the side of reliability and safety.
Yes, the coil and contacts are a relay. That's the way it's shown in schematics. Relays can have many contacts configurations. The one shown is a single-pole single-throw, or SPST, relay. Other common ones are single-pole double-throw (SPDT) and double-pole double-throw (DPDT).Yikeessssss!!! .... I bet you felt alittle rough around the edges for a few days after that event !
Yes I'm having trouble making out that drawing. Looks like there are 3 switches involved. Is that a relay where the coil is and next to it, is a switch/contacts.
Thanks, that's the ultimate comment, it most greatly appreciated.This has been a very educational thread.
