Indycars
Not a problem, you have no obligation to solve my problems.Sorry for the delay, got tied up. The schematics are pretty busy with dash circuits, etc. looks like you have it under control now anyways.
Looks good. Some minor points: the relay in the switched power circuit would probably smoke and melt before the 100 amp fuse blew. I'd replace both of those 100 amp fuses with something closer to the expected loads. Make sure the relay can handle the amps you will need. Most of the cheap auto relays are only good for 30-40 amps. My car is wired much like yours and I have lots of electrical loads and use a 50 amp relay. The alt light circuit doesn't need a diode. The S and L leads on the alt carry tiny current, so 16 or 18 or 20 gauge is fine. And I would wire the anti-theft switch to the ACC post on the ignition switch.
Two things: Fuse ratings seem too high for the expected loads. I have 40 amp main fuse and with everything on I'll never get there. Calculate maximum load and add 25% for fuse rating. Remember, the fuses are to protect the wiring so they don't burn up and start a fire. Amp load rating on a wire depends on gauge and length. Find a table that shows that relationship on the net and go from there. Also, you need a relay for the starter solenoid. You do not want the ignition switch to handle the surge current as the solenoid engages; it can be over 100 amps for a very short time. You probably do not need the relay for the switched power load. Some use them some do not since those loads seldom come close to the ignition switch ratings. Just my observations and experience. Others will chime in I'm sure.
Using 16g as the smallest size is fine. You can always go bigger on wire. The fan power should connect direct to battery, with it's own in-line fuse and a relay. The temp switch turns relay on-off. Relay coil power thru fuse block connected to switched power. On attached drawing I relocated the neutral start switch to the ignition relay circuit. I have Ford alternator so it will be a bit different than yours. Note that electric choke is tied to the S term of alternator that supplies 12v when engine is running. I do not know what the S term does on yours. I have body and engine harness connectorized so I can remove body without having to "Unwire" anything.View attachment 11067
I have a software program around here somewhere called electronics workbench that allows one to build circuits, test, and print them. I haven't used it in a while, but it would be good for someone interested in designing harnesses, etc and printing them for future use or distribution. I used it when I was enrolled in Devry back in 98. If I had it loaded, it is easy to print schematics and the like. I keep an old pc to use old software, but haven't used any of it lately. if you can't get it working with the info you have, I can put a schematic together if you want, but it looks like you got things under control. My experience with older cars is that if you plan to use lights that require much amperage, you should use relays, because the old switches wont tolerate much heat, especially the turn signal switch that the brake, signal, and flasher lights go through.Eventually I would like to get confirmation on all my drawings, so here is the next one for the "Power and Charging" circuits.
The numbers next to each alternator connection is the wire gauge. Let me know what you think, will it work???
Two tips: 1) Never post just after a nap. 2) I don't like any big currents going thru the ignition switch, so I use relays for the switched power, the ignition and the starter circuit. 3) Never post just after a nap....
Noted ...... thanks!![]()
Here is an easy improvement while you're rewiring. Marine terminal strips with 10-32 studs make ideal distribution blocks for power and ground. 12ga wires direct to battery. Makes everything easy and allows for future expansion. The plastic cover has been removed from the ground strip to show the studs.
I hope it doesn't come to that, but if it does ........I have a software program around here somewhere called electronics workbench that allows one to build circuits, test, and print them. I haven't used it in a while, but it would be good for someone interested in designing harnesses, etc and printing them for future use or distribution. I used it when I was enrolled in Devry back in 98. If I had it loaded, it is easy to print schematics and the like. I keep an old pc to use old software, but haven't used any of it lately. if you can't get it working with the info you have, I can put a schematic together if you want, but it looks like you got things under control. My experience with older cars is that if you plan to use lights that require much amperage, you should use relays, because the old switches wont tolerate much heat, especially the turn signal switch that the brake, signal, and flasher lights go through.
About the diode; I could have been clearer. If you use the ACC post for switched power, and put the ignition on the IGN post, then you don't need the diode. The diode is just to keep power from getting from the alternator to the ignition, causing the motor to keep running. I put all the things needed to run the motor (ignition, EFI, electric fuel and water pumps) on the IGN post, and everything else on the ACC post. This way you can play the radio, turn on lights, etc without powering up all the stuff needed to drive.
Are those Blue Sea fuse blocks? That's what I use!
PotvinGuy said:And I run a big cable from the alternator case to the battery negative terminal. Don't like to depend on any part of the car for ground, especially when talking about really big amps.
