these two boys are havin fun... well, make that 3.. im a toys r us kid also.Ain't that the the nuts. Screams of excitement and exhilaration. That's what a T Bucket is all about. Sir, you have my admiration and respect.
Yes he did.Jarrett. Your dad did good, don't you think?
lol... my boy jarrett couldnt hold the fear in...
That was Jarrett... He said his hat blew off then that cackleWhat fear, that was a Rebel yell for the people by the right side of the road. Whose cackle was that at the end of the run ?
I tried the same thing with tires pressures, but I found out that higher pressure was better. I figured that a low tire is just another spring, but without any shock control. I run mine at the maximum tires pressure of 35 psi. YMMV !!!Playing with tire pressures, toe. 6° caster.. 1/8 toe out..22 psi front.... Down from 28.
.60 over 283 balanced rotating assembly.Another thought is to teach the boys to go over the whole car with a torque wrench and open end wrenches (maybe even marking paint) to ensure all bolts are properly tightened. With their youth & energy you could have the whole car throughly checked in a couple of hours.
I echo Fred's opinion. Or at least try it.
By the by, what are the engine specs again?
John
