Mr. Fixit
If you are going with the teflon buttons, have the holes punched in the leaves. Drilling will discolor the chrome. Any shop with an Iron Worker will be able to do this for you. Tell them to use plenty of oil so as not to damage the chrome. When installing the button, use WD-40. Not only dose the button slide in easier but it will help to keep the hole from rusting.
Here's a tip from the old time T racers. They would run a needle bearing from a u-joint about 1" up from the ends of the leaf. I have tried this and it works. You need to run a pretty good shock with this.
Ron, I like the needle bearing idea a lot. What keeps it there? Just the constant pressure? Punching the leaf with the chrome already there will break the chrome and it will rust...
Thanks,
