When mounting the engine, keep in mind if you ever plan on adding a blower, so you can allow room between the radiator and crank pulley for the blower belt and pulley. I know you didn't initially advertise that you wanted to do that, but if you ever do, be ready! Most of the ones I have seen have the firewall about 1-2" behind the parting line between the block and bell housing. Just allow room for whatever distributor you plan to use, assuming it's a Chevy engine. I think they look better as close to the distributor as possible, within reason, but have seen some with more room that look ok. It's a personal taste decision.Plans say 90" to long cut. I added 10", so 100" on the long cut welded up yielded the 95" im pretty close to your set up. I still need body on site to be sure. I sure appreciate all the help. Maked my build easier.![]()
settled on 51" radius rods front and rear. if she bows up on me ill put a iron cross gusset in the middle of rear radius rods for strength. ccr uses a Z. I seen one on here with a big o T.
I better get me some of them.
Im anxious to get this chassis rollin. Maybe i should run 60/40 drag shocks up front?
