Good question. I thought the same. I'm using an IR gun and the reading is pretty close. The thermostat housing reads 221 and the top of the rad (near the cap) reads 224 when the gauge reads 230 F. The gauge is a Classic Instrument (All American Series)Are you sure that your gauge is reading correctly? I'd sure check that temperature with another gauge to be sure. Harbor Freight sells an inexpensive lased light detector made by Cen-Tech. Give it a try.
I was going to say the same thing. Also, sbf's have two different waterpumps, one goes forward and one turns backwards. Are you sure you have the right waterpump for the belt configuration you have?
Just think how good you will feel when you do solve the problem.
This might be tough to determine. There is no indicator/pointer. Is there a way to determine without?Time, time, time is on my side, yes it is... What's your timing?
...and 230 is not deadly as long as you're not spouting steam and boiling water. If it is stable at 230, that's not overheating, it's just...hot.
Sorry, forgot to mention that the engine did overheat. This is what led me to investigate. I thought 230 was normal until I ventured a little further in distance.This might be tough to determine. There is no indicator/pointer. Is there a way to determine without?
Okay. I attached a vacuTime, time, time is on my side, yes it is... What's your timing?
I attached a vacuum meter and it was in the late timing section, not that far off from normal. I advanced the timing slightly and it now sits in the normal zone. Haven't tried driving it yetTime, time, time is on my side, yes it is... What's your timing?
If you have an IR gun , shoot the outlet of the radiator too and see what temp the water is coming out of the rad. Then you can work out where the problem is. Is the motor making a ton of heat or is the radiator just not doing it's job well enough.
As Potvin Guy says, has the car ever been properly tuned.? Is it running lean? Vacuum leak?,Where's the timing at idle? and when you're cruising? All will contribute to it running hotter than you'd like.
Is it possible to put a larger fan on? It doesn't matter if it overhangs the tanks a little, as there will still be more area of the core with air moving over it. See if you have a decent size wire running too the fan , from the relay. Small wire will not help. And see if the fan is a reputable brand. Some of these offshore fans have puny motors that won't pull as much air as a decent fan. The size & weight of the fan motor is a good reference.
Those corrugated / universal/ "donkey dick" radiator hoses will slow water flow down, so change them to a decent smooth hoses if you can and you may be able to buy a larger crank pulley or smaller water pump pulley to speed the water flow up a bit?.
Good to see, checking the basics. Most electric fans come with a shroud. You should not need an additional one. With that said, I am not very hopeful of that being a cure. If you can cruise at 40+ mph that thing should not overheat. You do not have the rad blocked off with a tight mesh grill or anything, do you? I do not understand the 500 vacuum reading, but the idle rpm in neutral and drive do sound right. Your vacuum reading should be something about 20 inches plus or minus 5, or there about. I never did see a reply on any specs on the engine, head gaskets, etc. Do you have the vacuum adv hooked to the manifold vacuum. That will pull a lot of advance in at idle. If so, just pull and plug it and see what happens. Better get it done, Mike's site time is surely limited. Get the biggest fan that will fit. Watch the amp ratings, the higher the better, just wire it sufficiently.
roadmonster - I'm trying to understand what you mean by pusher fan. Are you saying that my fan needs to be attached to the front of the radiator and pushing fresh air towards the engine? The fan I currently have is attached to the inside of the rad and pulls fresh air in.Why don't you have a pusher fan? That sounds like the problem. I have a pusher with a switch but leave it on. If I turn it off, it will soon overheat.
